jonnyhubcap
Dec 31, 2018Guide
RBR50 with two satellites (RBK53?) plus Orbi Voice
Will the new Orbi Voice Smart Speaker add-on work if I already have an RBR50 router purchased as a package with two satellites? I did not think I could add more than two satellites to the router and ...
- Dec 31, 2018
RBK50 is a base router and 1 satellite, the RBK53 is a base router and two satellites. HW is same otherwise.
Looks like the RBK50V with Voice is it's own router and would not connect to a existing RBK system:
Dec 31, 2018Guru - Experienced User
ekhalil
Jan 01, 2019Master
The RBK50V consists of RBR50 and RBS40V. The router is a "normal" RBR50, the Voice unit (Amazon Alexa) is in the Satellite RBS40V.
- FURRYe38Jan 01, 2019Guru - Experienced User
