Jamie0691
Sep 28, 2021Aspirant
RBR50 Wont Boot
Bought a second hand RBR50 from eBay, currently it wont boot correctly, attached a USB > Serial adapter and it intermitently will boot up but a lot of the time it will stop at this stage in the boot ...
- Sep 28, 2021
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-1-18sf-hw-v-9-2-5-1-18-1sf-hw.64414/page-3#post-590839
https://community.netgear.com/t5/Orbi/Is-my-13-month-old-RBR50-bricked/td-p/2009904/jump-to/first-unread-messageIF this doesn't help, send the RBR back to seller.
Sep 28, 2021Guru - Experienced User
CrimpOn
If it won't boot, it is defective. If it was represented as "working", then return it for a refund. If it was advertised, "parts only" or some such thing, you're screwed.
