e-squared
Mar 02, 2019Aspirant
RBR50 won't get IP from SB6183
Orbi RBR50 won't get the ip from a surfboard 6183.
- Mar 03, 2019
Yes, you only need to unplug the modem for 30-1minute. Glad it's working now.
Mark your post as solved for others to know for future reference please.
Enjoy.
e-squared wrote:
Update to everyone.
I let the modem unplugged overnight and just went through process of hooking it up and it worked. I know the modem retains the MAC address of possibly 2 devices, so does the Orbi have a problem with this and once the modem loses the retained MAC addresses then it will work?
Once again it is working.
Just a weird issue.
Thanks for the help.
CrimpOn
Mar 02, 2019Guru - Experienced User
The first step might be to connect a computer (desktop, laptop, Mac, PC) that has an Ethernet port directly to the ARRIS modem. Once it connects, open a DOS prompt and type "ipconfig /all" and note which IP the ARRIS has given the computer. What does it say about the Ethernet port? If the computer does not get an IP address from the ARRIS, the problem is with the ARRIS.
Then, remove the computer and connect the WAN (yellow) port on the Orbi to the ARRIS and connect the computer to one of the LAN ports on the Orbi and restart the computer. Open the DOS prompt and repeat. What IP does the computer say about the Ethernet port now?
- e-squaredMar 02, 2019AspirantI have connected to PC and it does get the IP that the modem is getting from the ISP. But have not tried the PC which would get an IP from the Orbi. I have tried everything, factory reset, power off/on, boot this, boot that and nothing works. This should not be this difficult.
- CrimpOnMar 02, 2019Guru - Experienced User
e-squared wrote:
I have connected to PC and it does get the IP that the modem is getting from the ISP. But have not tried the PC which would get an IP from the Orbi. I have tried everything, factory reset, power off/on, boot this, boot that and nothing works. This should not be this difficult.It might be worth checking the Orbi's Internet settings, under the "Basic" tab, select "Internet". and the box should be checked next to "Get Dynamically from ISP". In the boxes to the right that are greyed out, are there any values there?
The IP address the PC received directly from the ARRIS modem... was it a "private" IP (192.168.x.x) or a "public" IP?
