e-squared
Mar 02, 2019Aspirant
RBR50 won't get IP from SB6183
Orbi RBR50 won't get the ip from a surfboard 6183.
- Mar 03, 2019
Yes, you only need to unplug the modem for 30-1minute. Glad it's working now.
Mark your post as solved for others to know for future reference please.
Enjoy.
e-squared wrote:
Update to everyone.
I let the modem unplugged overnight and just went through process of hooking it up and it worked. I know the modem retains the MAC address of possibly 2 devices, so does the Orbi have a problem with this and once the modem loses the retained MAC addresses then it will work?
Once again it is working.
Just a weird issue.
Thanks for the help.
