Ultramarine440
Sep 29, 2021Aspirant
RBR50 Worked Flawlessy since Purchase in 2018 - Now experiencing Wifi Disconnects from my devices
Hello All, I have have had a flawless WiFi setup with the RBR50 and one RBS50 satellite at my home from the initial setup back in 2018. Over the past few weeks, I have been experiencing intermit...
- Oct 01, 2021
Yes. Something to turn OFF and see if the Orbi system works with out it.
Ultramarine440 wrote:
OK, I decided to rename my WiFi network and temporarily try another router. I set up the new router with a new WiFi network name. What surprised me is that I still saw a network showing up in my WifI Analyzer program with the old network name. I forgot that I had a TP-LINK RE200 range extender plugged into an outlet in my basement. I was using it as a wireless ethernet adapter while I was working on an extremely old computer in the basement. Well, that basically replicates your network, and I'm wondering if it was causing problems with the wireless mesh. Regardless, I am going to keep the current setup in place for a few days and see how things go. Could that TP-LINK range extender have caused issues with my Wireless Mesh? It was broadcasting my old network SSID on both the 2.4GHz and 5GHz bands.
Sep 29, 2021Guru - Experienced User
Is Armor or Circle enabled on the RBR?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Ultramarine440
As of my initial post, NO, but I went ahead and ran a full reset and setup from scratch. I downloaded the Orbi app to my smart phone and ran through the setup. I noticed one weird issue with the "routerlogin.net" certificate both on my phone and one of my computers initially, but that problem went away after a couple of minutes.
1920 square feet, not including a large basement...where my RBS50 satellite is set up. It is
I'm guessing between 60-70 feet.
No Armor or Circle enabled
currently on channel 48 for 5GHz and channel 8 for 2.4GHz. Router was set to "auto" for 2.4GHz
The "WiFi Analyzer" Microsoft Windows app that I have installed is showing "76-77 available networks
Channel 48 seems like a good choice for 5GHz according to this app.
I'll hold off on trying the Beamforming for now since I have made several other changes
Quick question: Was performing the configuration reset recommended after the latest firmware was applied? Also, the Wifi Analyzer app seemed to indicate that channel 8 was one of the least crowded 2.4Ghz channels, so I left the 2.4GHz channel setting to "auto" in my current configuration. I'll give it a day now that I have done a complete reset and reconfigure on the router.
One more quick question: Is the "backhaul" between the router and the satellite possible what shows up as "HIDDEN" when I run he WiFi analyzer app? It always shows up as the same signal strength as my network and it shows up on whatever channel that my wifi is on when I was experimenting with changing the channel for 2.4Ghz.
I will follow up in 12-24 hours. Thanks again!
- FURRYe38Sep 29, 2021Guru - Experienced User
I'm guessing between 60-70 feet. <Maybe a bit too far however keep an eye on it for now.
Any Wifi Neighbors near by? If so, how many?currently on channel 48 for 5GHz and channel 8 for 2.4GHz. <Use channels 1, 6 or 11. Other channels are sub channels used by the router system. Router was set to "auto" for 2.4GHz
Channel 48 seems like a good choice for 5GHz according to this app. 👍Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Quick question: Was performing the configuration reset recommended after the latest firmware was applied? Yes.
Also, the Wifi Analyzer app seemed to indicate that channel 8 was one of the least crowded 2.4Ghz channels, so I left the 2.4GHz channel setting to "auto" in my current configuration. I'll give it a day now that I have done a complete reset and reconfigure on the router. <Use channels 1, 6 or 11. Other channels are sub channels used by the router system.
One more quick question: Is the "backhaul" between the router and the satellite possible what shows up as "HIDDEN" when I run he WiFi analyzer app? Yes. It always shows up as the same signal strength as my network and it shows up on whatever channel that my wifi is on when I was experimenting with changing the channel for 2.4Ghz.
