AppleCh
Oct 23, 2023Aspirant
RBR50 WPA2-Personal won’t save
I just set up an old Orbi rbr50 and when I try to save he security to WPA2-personal, it always reverts back to WPA2/WPA2-Personal. Does anyone know how to fix this? Thank you!
AppleCh
Oct 24, 2023Aspirant
My firmware is v2.7.4.24 and there are supposedly no upgrades for it. My iOS devices indicate that the WPA/WPA2-Personal is weak security option. So I keep trying to select WPA2-Personal.
Andy my security screen looks different than yours. You have Wireless Settings where mine is WiFi Settings. It is Security Method and has three options:
1) None
2) WPA2-Personal
3) WPA/WPA2-Personal
KevinLiT
Oct 27, 2023NETGEAR Moderator
Hello AppleCh ,
Welcome to the NETGEAR Community!
The behavior from your RBR50 may be linked to your router being out of date. Please update your router to the latest firmware version which is 2.7.5.4. Please navigate to the links below to update your RBR50 to the latest firmware.
Navigate to the link below for the download file for your RBR50 (Ensure to update your satellites first):
https://www.netgear.com/support/product/RBK50#download
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
Community Team
