jostein_jansen
Aug 02, 2017Tutor
Rbr50
Hi, I bougth a wifi router rbr50 withbsatelite a couple of weeks ago. And i cant't get my wifi to work properly, i am still connected to my wifi network. But i loose my internet connection occatina...
Hector0125
Aug 02, 2017Guide
Hi,
You are not alone, myself and many others are having the same issue with wifi connection. Netgear is aware of this issue and it is working on this now. It has to do with latest firmware update (V1.12.0.18). I noticed today that NETGEAR has removed this firmware update from their download page: https://www.netgear.com/support/download/. That means they are really working on getting this fixed. Also, some people are reporting having problem with Samsung Galaxy S8, Phone will disconnect from ORBI wifi constantly, which that is my case personally, all other devices stay connected with no problem at all.
Schoeneberger
Aug 28, 2017Initiate
having the same issue with a rbr50 on galaxy s8 plus. wifi drops all the time, doesn't happen on any other router.
heard if you connect using guest that may help. This is a real problem. anyone know of a fix
- JMU1998Aug 28, 2017Luminary
Schoeneberger no word on fix from Netgear Engineering yet hopefully fix is coming in Firmware
