jostein_jansen
Aug 02, 2017Tutor
Rbr50
Hi, I bougth a wifi router rbr50 withbsatelite a couple of weeks ago. And i cant't get my wifi to work properly, i am still connected to my wifi network. But i loose my internet connection occatina...
Schoeneberger
Aug 28, 2017Initiate
having the same issue with a rbr50 on galaxy s8 plus. wifi drops all the time, doesn't happen on any other router.
heard if you connect using guest that may help. This is a real problem. anyone know of a fix
JMU1998
Aug 28, 2017Luminary
Schoeneberger no word on fix from Netgear Engineering yet hopefully fix is coming in Firmware
