Routerxchanges's avatar
Jan 28, 2018
RBR50
The past week and a half I have had to do a “new setup” on my Orbi app. The WiFi works perfectly fine on all devices except my iPhone. I have to go to the Orbi app and do the “new setup” in order for the WiFi to work on my iPhone. Any suggestions on why this is happening? Here is a screen shot of what I get when I open the Orbi app.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    In you wifi settings of your Iphone try and remove all the networks that are related to your orbi unit then try connecting the phone to the network again.
    DarrenM
  • Did the suggestion help? Same thing happens on my iPhone all the time. It’s frustrating. Love the product itself though.
    • Routerxchanges's avatar
      Routerxchanges
      It did not help. The system works great, but anytime I open the app it is telling me that my network isn’t set up. Not sure if it is an iPhone thing or the app itself.
      • DarrenM's avatar
        DarrenM
        I will look into this issue and pass it up to engineering.
        DarrenM
