JohanLangius
Jul 29, 2018Aspirant
RBR50
We continuously have a dropping WiFi connection and then the device asks for the WiFi password. Both manually entering the password as sharing through the Apple device is causing a password error.....
JohanLangius
Thanks for your quick reply. I just disabled Daisy chain. Fast roaming amd Mimo was already disabled. Hope this works
Distance is max 35 ft. Home is 1500 sft. Problems mostly occur close to the hub (less then 10ft).
Jul 29, 2018Guru - Experienced User
That small of a home, you might only need the base router and not a satellite
See how it goes. If problems still happen, try with out the satellite..
