Rgwelker
Dec 17, 2018Tutor
RBR50
The Orbi won’t allow 2 new iPhones to connect to my network longer than a few minutes before toggling them to blocked in access list. I slide the switch to allow them then it first toggles one off th...
ekhalil
Dec 17, 2018Master
Please deactivate "Access Control" in the web GUI:
And then click Apply.
This will clean all your Access Contol list. If you want to use the feature for other devices then add them again.
- RgwelkerDec 17, 2018TutorThank you. But isn’t my network less secure by not using access control?
- FURRYe38Dec 17, 2018Guru - Experienced User
Access Control is only for what you want or don't want to connect to your local side of the network for whom ever is in your household. Like setting up times frames for kids who want access and when parents don't want them to have access. This doesn't do anything for who tries to connect from the outside or the Internet side. The firewall automatically handles that.
Rgwelker wrote:
Thank you. But isn’t my network less secure by not using access control?- RgwelkerDec 17, 2018TutorExcuse my ignorance. So is access control different from MAC filtering?
