dkstar22
Feb 18, 2019Aspirant
RBR50
GM I would like to know if the satellite stays blue when connected properly with the router
michaelkenward
Feb 19, 2019Guru - Experienced User
If you are asking about the working of your Orbi device, try posting in the section of this community for Orbi systems.
There is also support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
- dkstar22Feb 19, 2019Aspirant
Good Morning, I just brought the orbi RBR50 the router on the main floor put the satellite up stair, my question is with satellite upstairs we still kick off the game my son is playing on his iPad
or slows down I was wondering if I have set up right, is the blue light on the satellite supposed stay blue
- michaelkenwardFeb 19, 2019Guru - Experienced User
I provided a link to the manual (see above). Look at the section Optional Orbi Add-On Satellite LEDs.
dkstar22 wrote:
....is the blue light on the satellite supposed stay blueNo.
For more, and probably better, advice, please post in the right section.
- CrimpOnFeb 19, 2019Guru - Experienced User
The ring at the top of the satellite turns blue for three minutes once it is correctly connect to the router. Then it turns off. Here is that section of the manual:
What it your satellite doing?
