ziggyray
Jul 14, 2019Aspirant
RBR50
Hello, I have contacted netgear and they could not figure out why I can not get download speeds that I should be getting so they replaced router but Iam still having issues and have done all basic tr...
michaelkenward
Jul 15, 2019Guru - Experienced User
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
Having two routers on a network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
