ziggyray
Jul 14, 2019Aspirant
RBR50
Hello, I have contacted netgear and they could not figure out why I can not get download speeds that I should be getting so they replaced router but Iam still having issues and have done all basic tr...
ziggyray
Jul 15, 2019Aspirant
It is router mode, I have no modem it is a data jack with service being fiber also, test speeds both wireless n wired and have the latest firmware v2.3.5.30, but speed test show ok around 100 down and 290 up but it takes forever to load pages and wont load Facebook pics or very little of the page so don’t understand how speed test show I should b ok but actual results prove different, I have been thru everything and cant see what is wrong or what to do.
Jul 15, 2019Guru - Experienced User
Can you tell us if the ORbi is getting a 192.168.#.### or maybe a 10.something IP address on the WAN port? If not, it maybe a ##.##.###.### address...
Please check the statistics page on the Orbi. Ensure the WAN an LAN ports are reading 1000Mbps for connection rates.
Do all devices or PCs exhibit this slow in internet speeds?
Has a factory reset been performed and setup from scratch using the setup wizard since the FW update?
