Tarheeldan
Sep 13, 2019Aspirant
RBR50
Tried to upgrade (through "Check For Updates) Firmware from v2.3.1.60 to v2.3.5.30 and it gives me a message "There was a problem checking firmware update". How do I overcome this problem?
CrimpOn
Sep 13, 2019Guru - Experienced User
Tarheeldan wrote:Tried to upgrade (through "Check For Updates) Firmware from v2.3.1.60 to v2.3.5.30 and it gives me a message "There was a problem checking firmware update". How do I overcome this problem?
Using the Orbi web interface or the Orbi "app"? This forum seems to be cluttered with questions from people having issues using the app to upgrade firmware. I, personally, use the web interface for anything important on the Orbi.
Tarheeldan
Sep 14, 2019Aspirant
I tried with the app and with my computer and neither one worked.
- CrimpOnSep 14, 2019Guru - Experienced User
Another method with the computer is to do a "manual update". First, navigate to the Netgear Orbi support web site and download the firmware files for RBR50 and RBS50.
https://www.netgear.com/support/product/RBR50.aspx#download
Extract both zip files and place the ".img" files on the computer in a place that is easy to "Browse" to (I often use the Desktop).
First, connect to the web interface of each satellite using the IP address that is shown in the "Attached Devices" screen.
The satellite login is "admin" and the same administrative password as the router.
Select Firmware Update from the Home Page.
After updating all of the satellites, do the same thing with the router.
Log in, navigate to Advanded tab->Administration->Firmware Update->click on Manual Update.
Good LUck
