ChinoMorales
Oct 03, 2019Tutor
Rbr50
I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though. Thanks a lo...
- Oct 03, 2019
Just power OFF the modem when you change ISPs for 1 minute then back on.
ChinoMorales wrote:I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though.
Thanks a lot.
Oct 03, 2019Guru - Experienced User
Thanks a lot.
michaelkenward
Oct 05, 2019Guru - Experienced User
... and while you are doing that, also turn off the Orbit router and then turn that back on when the modem is up and connected.
- ChinoMoralesOct 05, 2019Tutor
I waited for the new ISP tomsend the signal to my modem as did as suggested by you, all working fine now, thanks again.
