ChinoMorales
Oct 03, 2019Tutor
Rbr50
I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though. Thanks a lo...
- Oct 03, 2019
Just power OFF the modem when you change ISPs for 1 minute then back on.
ChinoMorales wrote:I'm using Orbi RBR50, router with two satellites and we are changing our internet provider, do I have to do a "New Setup" once I have the new provider? I will be using same modem though.
Thanks a lot.
Oct 03, 2019Guru - Experienced User
Thoretically no. I would recommend it however. It might work great once the new ISP provisions your modem but it might have issues. Just take a backup of your configuration so you can restore it once you've got the new setup provisioned.
ChinoMorales
Oct 05, 2019Tutor
Thanks a lot for your help.
