Dobyhawaii
Mar 16, 2020Tutor
Rbr50
How do I get update if app is having trouble detecting if new update is available. I checked internet and there is an update available. Can I download update to my phone and send to modem using app...
- Retired_MemberMar 16, 2020
Can I download update to my phone and send to modem using app?Don't worry about FW updates. NG will push critical updates to you automatically.
Mar 16, 2020Guru - Experienced User
If you want too, you can use a PC or laptop to download FW updates. Download the FW updates from here:
https://www.netgear.com/support/product/RBK50.aspx#download
Use a web browser to apply the FW udpate to the RBR.
For any Orbi app help and information, please post here in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Dobyhawaii
Mar 16, 2020Tutor
Thank you!
Dobyhawaii wrote:
Thank you!Aloha
