swathi
Apr 06, 2020Aspirant
RBR50
Getting Router not found in Orbi app. Reset the modem but no luck.
Apr 06, 2020Guru - Experienced User
And is there a ISP modem in front of the Orbi router? If so, what is the Manufacturer and model of the ISP modem?
swathi
We have Modem thats provided by ATT.Model is BGW210-700.
- FURRYe38Apr 06, 2020Guru - Experienced User
This modem arlready has a built in router and wifi>
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend you try option #3...
