Homersignalman
Apr 18, 2020Aspirant
RBR50
Hi,
I'm having problems updating the firmware of my new (obviously not the firmware) Orbi RBR/RBS 50. They were supplied with firmware v2.1.4.16 and I am trying to install v2.5.1.8 but without success. I read somewhere that I cannot update directly from the installed version but instead need to upgrade to an intermediate one and then update that to the latest. Does anyone know which version I can install to enable me to upgrade to v2.5.1.8
Any help greatfully recieved.
John
- Retired_Member
Homersignalman wrote:Hi,
John
Stop do not pass go
lots of complaints about 2.5.1.8
if your system is working leave it alone
- HomersignalmanAspirant
Hi VAJim
The trouble is, it has never worked since I unpacked it 3 days ago. When I first turned it on I got a message saying Firmware update required and before I had a chance to read what else it said the deed was done and since then it won't connect to the Satellite or the modem. Perhaps you could reccomend an earlier version that I can update to that isn't riddled with problems.
John
- Retired_Member
Homersignalman wrote:Hi VAJim
John
I've been on 2.3.5.30 since October 2019 with no problems
You'll need v210 to be applied to your RBR first before updating to any recent FW udpates. You can direcly apply v2.5.1.8 to the RBS first. Then apply v210 to the RBR then apply v30 or v2.5.1.8. V2.5.1.8 works as well.
John
- Retired_Member
V2.5.1.8 does NOT work for many...ask NG support
- BigRuneApprenticeNo firmware is stable. Just return it. I am sorry, Orbi is a dead end.
