makingitworse
Jun 02, 2020Follower
RBR50
My RBR50 is setup as a router using FiOS and when connecting to my laptop via ethernet cable directly from my Verizon router it's on average an 880 mbps connection, accoring to speedtest.net. When I ...
Jun 03, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
makingitworse wrote:My RBR50 is setup as a router using FiOS and when connecting to my laptop via ethernet cable directly from my Verizon router it's on average an 880 mbps connection, accoring to speedtest.net. When I connect from my Orbi to my laptop via ethernet cable or Wifi it's an 92 mbps connection. I tried switching to AP mode and the connection speed is actually slower. Is there a reason my Orbi is so much slower than a direct connecton from my FiOS router? I'm not sure if I'm missing something or just don't know that it should be slower.
