Poppyozzy's avatar
Poppyozzy
Follower
Jun 10, 2020
Rbr50
After enabling guest user and then disabling, my Orbi rbr50 is now sporadic. I have rebooted and reset modem several times but still not as good as it was before enabling and disabling guest user. Any suggestions?
1 Reply
  • FURRYe38's avatar
    Press the back reset button for 15 seconds then release.
