ssadegh9's avatar
ssadegh9
Follower
Sep 12, 2020
RBR50
This may be a very basic question, but is the admin password same as the WiFi password, like the one I type into devices to connect to the network? Or are they different things?
    It depends how you setup your account. The admin password is what is used to login to orbilogin.com or the app. Your WIFI password is usually different.
1 Reply
