Toeknee72
Sep 15, 2020Aspirant
RBR50
Will the RBS40V-200 speaker/WiFi extender work with my Orbi router RBR50?
- Sep 15, 2020
Toeknee72 wrote:Will the RBS40V-200 speaker/WiFi extender work with my Orbi router RBR50?
Yes. Check the product data sheet:
https://www.netgear.com/images/datasheet/orbi/RBS40V-200.pdf
"Works with ANY router, but is optimized for the Orbi system."
Notice there are two different firmware loads:
- Extender mode
- Orbi mode
https://www.netgear.com/support/product/rbs40v-200.aspx#download
p.s. Mine is arriving tomorrow. If it doesn't work (a) I will return with an update, and (b) you will probably hear the cursing from wherever you are.
CrimpOn
Sep 15, 2020Guru - Experienced User
- Extender mode
- Orbi mode
- Toeknee72Sep 15, 2020Aspirant
Thanks I appreciate it
