RoSk
May 04, 2021Follower
RBR50
I have a RBR50 Orbi Home Mesh system that works well downstairs but due to building material or whatever it is not strong enough upstairs (losing 90% speed). Upstairs I do have a wall-mounted Power...
May 04, 2021Guru - Experienced User
There isn't an Orbi POE rated access point for the consumer equipment.
the only Orbi one I know is the SRC60 which is the orbi pro. They don't mix between consumer orbi and orbi pro versions.
