Dem100
Jul 21, 2021Follower
RBR50
How many satellites (and which ones preferably?) can be attached to router ORBI RBR50?
1 Reply
the official response is you can add up to 6. I've seen users with more but it tends to decrease performance of the sysem.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
In terms of compatible with that router:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50V
Just keep in mind, the 50 series uses the 1733mbps backhaul while the other use the 866mbps backhaul. So they work but with a narrower backhaul.
