Maksym1989's avatar
Maksym1989
Follower
Apr 16, 2023
rbr50
I lost my sticker from the bottom of router.. how can I find all that info again..I there were password, s.number everything?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Crikey. Those labels are almost impossible to get off.
    You won't be able to recover the WiFi password. That's customised for your box.
    The rest of the details are standard. Access to the browser graphical user interface (GUI) is the defaults as stated in the manual.
    The WiFi SSID should show up when you look for it with a WiFi client. Something like NETGEARXX.
    If you login into the GUI you may find the SSID visible there. Look in Wireless Settings.
    When you have done that you can change it to what you like. You might also like to note down the default settings.
