MichaelSasa
Aug 07, 2024Follower
RBR50
I received a new Virgin Hub 5 and My Orbi and satellite will not connect, I have reset and gone through it several times and always says not found. Is there a way to change to a new wifi network via ...
Aug 07, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network
What firmware is loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
