Yioti99
Oct 04, 2024Aspirant
RBR50
Can I add a newer version of satellite to my existing ORBI RBR50 mesh system ie RBS760
Oct 04, 2024Guru - Experienced User
- Yioti99Oct 04, 2024AspirantBased on the table the answer is no, at BEST Buy they insisted it works but at lower speed.l ( speed limited to RBR50) . I guess they are wrong ?
- plemansOct 04, 2024Guru - Experienced User
The best buy people are wrong. The chart is what you should go with.
Are you needing more satellites or faster speeds?
Some of the older satellites can be picked up pretty cheap on flea bay or buying a refurbished kit (then you get a backup router).
- Yioti99Oct 04, 2024AspirantThks for the reply, I need more satellites to extend signal range. Unfortunately it’s difficult to find them in the market
