Gpoulos
Feb 13, 2025Aspirant
RBR50
I have an ORBI RBR50 with 2 satellites that is not giving me a strong signal throughout the house. Does the firmware need updated? If so, how to update a firmware? I have it connected to a COX Commun...
Gpoulos
The home is about 4500sq and the satellite's are over 30 feet away. Do you think I need a booster?
Feb 13, 2025Guru - Experienced User
Are you having problems at the RBS? Might bring them closer bit to the RBR.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
