erkinfl
Dec 10, 2021Aspirant
RBR50/2 satellites - fast internet speed, slow wifi
I have an RBR50 with two RBS50 satellites. FW version on all is 2.7.3.22. My router is a Netgear CM1000. In the Orbi app, it reports my internet download speed as 360Mbps. But in my phone, Speedtest ...
Dec 10, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- erkinflDec 10, 2021Aspirant
Home size: 1530 sq ft. 1st satellite is ~35 ft. from router with two walls between. Second satellite is in separate garage, ~80 ft away? That was a wild guess. But as I mentioned, this setup has worked flawlessly for several years.
I'll take a look at the other options you've suggested, thx!
- FURRYe38Dec 10, 2021Guru - Experienced User
A factory reset maybe needed as well...
- erkinflDec 12, 2021Aspirant
So far I have tried the following:
- Factory reset router and both satellites
- Deleted all settings on iOs app
- Ran through steps on iOs app to set up the router (no satellites)
- Changed router settings to:
- Enable daisy-chain topology: off
- Enable 20/40 MHZ coexistence: off
- Enable implicit beam-forming: on
- Verified that router has latest firmware
- Added one satellite
- Verified that the satellite has latest firmware
- Turned off first satellite
- Added second satellite
As both satellites eventually seemed to be connecting, I moved one to its normal location, about 40' away in a different room. I then turned on both satellites and ran sync from the router again.
No matter where I position the satellites, after multiple attempts at syncing, one of them always reports its backhaul status as "Config Sync".
Any more suggestions?
