Milkfather
Apr 01, 2019Follower
RBR50/RBK50 Drops wifi..
Hey! I have a problem with my RBK50. From time to time it works perfectly but suddenly it just drops and im going online/offline every 30second. Im getting sick of doing factory reset after factory r...
Apr 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
