Milkfather
Apr 01, 2019Follower
RBR50/RBK50 Drops wifi..
Hey! I have a problem with my RBK50. From time to time it works perfectly but suddenly it just drops and im going online/offline every 30second. Im getting sick of doing factory reset after factory r...
jsturess
Apr 07, 2019Apprentice
I have one router, three satellites, 22 connected devices, firmware v2.1.3.44( right now) and have the same problem The gui where you can see the connected devices doesn’t show correct, it changes all the time. Do you also have this problem? Connection type for example changes between wired connected, wifi 2,4 to wifi 5 and so on for a device. Connected orbi also change all the time, to the nearest satellite, and after 20 sec its connected to the farthest away satellite and sometime the wifi is lost.
When I look into the menu for my speaker’s which is wifi connected, HK citation (bar and 500), it changes all the time between not connected to weak and excellent. I am so tired of this system. When will Netgear get this to work? I have had problem the first day i bought it. I really regret that i didn’t return it. I had my hope that they would resolve all the problem, but they haven’t. Every new firmware introduce another problem!!!!!!!!!! I will never more buy something from Netgear!!!!!!!!! My hope is gone for them.
I have tried to separate 2.4 and 5GHz, change transmit power, reset, restart and every firmware version out there and even tried the most of the features it has. But nothing helps!!!!!!!!
jsturess
See document for dropping wifi(1 router, 3 satellites one SSID for 2.4 and 5, latest firmware)
Help!
