uiucguy6
Jan 12, 2018Tutor
RBR50/RBK50 Drops WiFi every 30 seconds
Recently, my RBR50 has been dropping the WiFi connection every 15-30 seconds. Yesterday, I performed a factory reset. That seemed to work fine for about 24 hours, but the issue started again. The inte...
- Jan 17, 2018
I MIGHT have figured out the solution. Somewhere along the way, the satellite (RBS50) firmware went out of sync with the firmware for the router (RBR50). I have a feeling this is contributing to my internet wifi dropping every 15-30 seconds. Any devices I have connected via ethernet to the router have worked fine, therefore I was suspicious of the communication between the router and the satellite. The satellite's firmware was still stuck on V2.0.0.74 while the router's firmware keeps updating to later versions. Therefore, I assumed if I somehow get the satellite to update, then perhaps I can get it back in sync with the router and prevent dropped the dropped wifi.
Here are my steps:
1.) Download the latest firmware (V2.1.2.18) for BOTH the router and satellite from the NETGEAR support webpage for your Orbi device by going here: https://kb.netgear.com/000053549/RBR50-RBS50-Firmware-Version-2-1-2-18
(Important: You may want to either print off the directions on this page or stay on this page in your web browser.)
2.) Unplugged the modem (ethernet) connection from the router. (This is important to prevent the router from automatically updating the firmware.)
3.) Reset the Orbi to factory settings. (This reverts the firmware of the Orbi back into a more compatible state with the satellite.)
3.) While keeping your internet modem unplugged from the router, connect your pc via ethernet to the router, open your web browser, and allow the setup process to run. You may need to type orbilogin.com in your address bar if it doesn't automatically connect you to the setup process.
4.) During the setup process, you may need to skip or bypass any steps that asks you to connect to the internet. You can setup the router manually.
5.) Once you are have completed the setup process, you should be taken to the Orbi admin page where you can go under the Advanced tab --> Administration --> Firmware Update. Perform the steps as shown on this page to upload the firmware files you downloaded in Step #1: https://kb.netgear.com/000053549/RBR50-RBS50-Firmware-Version-2-1-2-18
6.) After you have updated the firmware of the router/satellite, they should now have the same firmware version. Go ahead and plug in your internet modem (via ethernet) into your Orbi router.
7.) You should now have a stable internet connection and wifi.
Please let me know if this works for you. So far this seems to have corrected the problem. In the future, when the firmware goes out of sync, these steps should be taken. Might want to keep these directions handy.
uiucguy6
Jan 17, 2018Tutor
Here are my steps:
