k9kids
Nov 29, 2017Guide
RBR50/RBK50 not in sync
Decided to log on and look at my current status. Satellite is pulsing white. Did a sync, but still the same. Both are at the latest F/W revision v2. 0.0.74. The satellite shows no internet conne...
DarrenM
Dec 04, 2017Sr. NETGEAR Moderator
Are you able to log into the satellited using its Ip address?
DarrenM
BillYoung
Dec 04, 2017Luminary
k9kids:
Welcome to the club. I have the exact same issue as you do. I was told to re-sync the satellite. I did that, and its ring flashed white for about an hour and 40 minutes. Once it quit, I tried the same thing again, and the results were the same: "No Internet". I'm still waiting for a response from DarrenM. My posting is currently on Page 3 and headed lower in the Community.
I'll keep an eye on your posting to see if you get a solution. Thanks for posting this.
BillYoung
- BillYoungDec 06, 2017Luminary
k9kids:
OK, here is your answer to your problem: power cycle the satellite, and re-sync both the router and satellite. That should clear the "No Internet" issue. It did for me. You can look at my posting to see any further details.
