Wangers
Jun 15, 2024Aspirant
RBR50/RBS50 - bricked?
Hello all, Just seeing if anyone has any further ideas on how I might progress with my reflash of an RBR50 to an RBS50. I faithfully followed the instructions here: https://eve.gd/2021/07/28/...
- Jun 15, 2024
Try a 30-30-30 reset on the RBR...
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
Try nmrpflash:
https://github.com/jclehner/nmrpflash
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-1-18sf-hw-v-9-2-5-1-18-1sf-hw.64414/page-3#post-590839
https://community.netgear.com/t5/Orbi/Is-my-13-month-old-RBR50-bricked/td-p/2009904/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/ORBI-RBR50v2-bricked-Solved/m-p/2338097#M145450
Jun 15, 2024Guru - Experienced User
Try nmrpflash:
Wangers
Jun 16, 2024Aspirant
Thanks Flurrye38
I had some success with your suggestion to use the reflash utility from github. It wouldn't let me reflash it to a satellite, but at least it let me reflash back to a base/router (i.e. rbr) so I can start again on my journey.
Thanks again!
