NikS55
Jul 13, 2020Aspirant
RBR50/RBS50 - can I connect a Netgear AC1750 Mesh Extender?
I have a working Orbi network with RBR50 and RBS50 satellite in my home. My son has just moved back home and brought his Netgear AC1750 Mesh Extender with him. We have tried to connect this with th...
- Jul 13, 2020
Most extenders are not compatible. Other users have contacted NG support abou the EX3700 and was reported to get FW from NG to make that work with the Orbi system. I got FW for my EX7700 that works with mine. Contact NG support to see if they might have something.
NikS55
Jul 14, 2020Aspirant
Excellent! I downloaded the latest firmware for the Ex6250 and it connected to my Orbi network successfully. Thanks for your response.
Jul 14, 2020Guru - Experienced User
Good to hear and glad to know that it works.
Enjoy. :smileywink:
- FURRYe38Jul 14, 2020Guru - Experienced User
My EX7500 works as well:
- Hardware Version: EX7500
- Firmware Version: V1.0.0.64_1.0.74Connection to Existing Network (2.4GHz)
- Signal Strength: 400 Mbps
- Name (SSID):
- Connection Status: ConnectedConnection to Existing Network (5GHz)
- Signal Strength: 867 Mbps
- Name (SSID):
- Connection Status: ConnectedExtender WiFi Status (2.4GHz)
- Name (SSID):
- Region: North America
- Channel: Auto ( 11(P)+7(S) )
- Wireless mode: Up to 400 Mbps
- Wireless AP: On
- Broadcast Name: On
- Wi-Fi Protected Setup: ConfiguredExtender WiFi Status (5GHz)
- Name (SSID):
- Channel: 149 + 153 + 157(P) + 161
- Wireless mode: Up to 867 Mbps
- Wireless AP: On
Here's my EX7700:
- Hardware Version: EX7700
- Firmware Version: V1.0.0.206Connection to Existing Network (2.4GHz)
- Signal Strength: 400Mbps
- Name (SSID):
- Channel: 11
- Signal Strength: 780Mbps
- Name (SSID):
- Channel: 48
- Name (SSID):
- Channel: 7(s) + 11(p)
- Region: United States
- Wireless AP: ON
- Broadcast Name: ON
- WPS: Configured
- Security Type: WPA2-PSK[AES]Extender WiFi Status (5GHz)
- Name (SSID):
- Channel: 149 + 153 + 157(p) + 161
- Wireless mode: Up to 866.7 Mbps
- Wireless AP: ON
- WPS: Configured
