u1nita
Mar 07, 2024Aspirant
RBR50/RBS50 daisy chain questions
My RBR50 and 2 RBS50's are still running fine for 5 years. 6 months ago I added another RBS50 to cover another area of the property - it's also running fine. I have a star configuration, 5GHz backhau...
CrimpOn
Mar 07, 2024Guru - Experienced User
If it is practical, an Ethernet connection is almost always superior to a WiFi connection. Running Ethernet cable inside a barn seems SO much easier than inside a typical finished house. "Go for it!"
