SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Apr 20, 2020Guru - Experienced User
Did you notice any devices appearing on the RBS and if they were displayed as unknown on the Orbi app or the RBSs web page?
theoak wrote:Add me to the sucker for punishment list :)
Orbi in Access Point mode
Attached Device List:
I am not seeing any real improvement. Still seems slow to pull them up. I can go to my devices and they work fine enough, but are still not listed in the Orbi browser. I still have those ones that for whatever reason, the Orbi refuses to see them - my router does - and they act as expected. If you are upgrading for this reason, you may be disappointed.
Satellite Acquisition:
There were some posts that this was faster. This seems to be the case. My wifi based backhaul would always go pink for about 10 seconds and finally flip to blue. Goes right to blue now. Now ... I am not say blazing fast by any mean; just, a little faster.
theoak
Apr 20, 2020Luminary
FURRYe38 wrote:Did you notice any devices appearing on the RBS and if they were displayed as unknown on the Orbi app or the RBSs web page?
No difference. Directly to the Orbi Satellite or Router GUI or iPhone App - does not list them. My router does and gives them IP address obviously and I see their traffic.
- Dd852Apr 20, 2020Luminary
This update nicely fixed the problem i had, which is that the Orbi ios app would not list devices as they were attached to satellites or router (it just listed them in the main device manager without showing where they were connected) . After the update all works as expected (and as it once did). Speed seems fine to all devices.
- FURRYe38Apr 23, 2020Guru - Experienced User
Upgraded my RBK50 system yesterday.
Working well as expected. Router mode.
- Retired_MemberApr 23, 2020
Dd852 wrote:This update nicely fixed the problem i had, which is that the Orbi ios app would not list devices as they were attached to satellites or router (it just listed them in the main device manager without showing where they were connected) . After the update all works as expected (and as it once did). Speed seems fine to all devices.
Is it pushed by NG or did you have to go looking for it?
I always manually download FW and manually install thru the RBS and RBRs web page. I didn't do a reset this time. Wanted to see how it worked with out doing a reset and setup from scratch.
