SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Apr 23, 2020Guru - Experienced User
I don't understand your question...
Retired_Member
Apr 23, 2020what part don't you understand?
- FURRYe38Apr 23, 2020Guru - Experienced User
"What does NG support recommend WRT firmware updates?"
- Retired_MemberApr 23, 2020
FURRYe38 wrote:"What does NG support recommend WRT firmware updates?"
You know what it means.
Are you referring to OpenWRT or DD-WRT?
Maybe restate your question better?
Open/DD-WRT isn't supported on Orbi if thats what your asking.
FURRYe38 wrote:Are you referring to OpenWRT or DD-WRT?
wow...I've never mentioned OpenWRT or DD-WRT, and again you know that
And your point is?
and my point is you have no answer.....perhaps someone else.
I did say I had an answer.
Contact NG support to what they recommend.
been there done done that.....looking for a consensus here...
Only other 3rd party FW that works on Orbi 50 series is Voxels FW.
