SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
larryindublin
Apr 24, 2020Luminary
Clearing browser cache for the win. Thanks FURRYe38.
Everything reconnected just fine so just given it the typical time for some of my devices to reconnect to strongest device.
Orbi is still by far the best router I've used. Sorry others have had issues.
Petiel315
Apr 24, 2020Tutor
do you have your satellites on different channels
I do not know the best practices for that
- CrimpOnApr 24, 2020Guru - Experienced User
Petiel315 wrote:do you have your satellites on different channels
When the Orbi selects channels for 2.4G and 5G WiFi, every Orbi device uses the same channels. So, if the configuration is "Auto" and the Orbi has selected channel 4 for 2.4G, then all devices use channel 4. If the user manually selected a channel, then every device uses that channel.
This is the design.
- Petiel315Apr 24, 2020Tutor
Should they be on different channels
