SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
CrimpOn
Apr 24, 2020Guru - Experienced User
Petiel315 wrote:do you have your satellites on different channels
I do not know the best practices for that
When the Orbi selects channels for 2.4G and 5G WiFi, every Orbi device uses the same channels. So, if the configuration is "Auto" and the Orbi has selected channel 4 for 2.4G, then all devices use channel 4. If the user manually selected a channel, then every device uses that channel.
This is the design.
Petiel315
Apr 24, 2020Tutor
Should they be on different channels
