SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
fredricr1
Apr 26, 2020Aspirant
Definitely new, so be gentle.
My RBR50 is currently using firmware v2.3.5.30, my RBS50 is on 2.5.0.38, and my RBS50Y (outdoor) is on 2.3.5.32. When I log into the orbi website for remote management and check for firmware updates, it shows none available. Any idea why the latest firmware update doesn't show up? Does this mean my Orbis (all 3) are not compatible with 2.5.1.16? Do I need to download and manually update instead? Lastly...any cautionary tips for updating firmware?
Sorry for the basic questions and thanks for the help.
Petiel315
Apr 26, 2020Tutor
Yes download manually that is what I had to do
no idea why automatic does not work
worst decision in buying the orbi garbage
- AnonymousApr 26, 2020
Petiel315 wrote:Yes download manually that is what I had to do
just to be clear ...no one 'has to' perform a manual upgrade, unless of course you're doing some sort of correction or reversion
automatic works fine....for the most part it works in the background and you should bever be worrying about it
