SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Apr 26, 2020Guru - Experienced User
I recommend avoiding the auto update FW section of the router. Many posters have had problems with this feature and is not stable to use. Seems to break systems or causes problems more than anything else.
First manually download the RBS and RBR FW files from here.
http://kb.netgear.com/en_US/000061838/
Unpack the FW from the .zip files.
Use a wired PC for this process. Safari(Mac), IE11, Firefox or Opera browsers are recommended.
Log into the RBSs web page and send the FW file there first.
Then send the RBR FW file lastly.
Factory reset the RBS and RBR and setup from scratch. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
I recommend keeping this method, as it's a proven method I and others have been using for years to update router FW.
fredricr1 wrote:Definitely new, so be gentle.
My RBR50 is currently using firmware v2.3.5.30, my RBS50 is on 2.5.0.38, and my RBS50Y (outdoor) is on 2.3.5.32. When I log into the orbi website for remote management and check for firmware updates, it shows none available. Any idea why the latest firmware update doesn't show up? Does this mean my Orbis (all 3) are not compatible with 2.5.1.16? Do I need to download and manually update instead? Lastly...any cautionary tips for updating firmware?
Sorry for the basic questions and thanks for the help.
Anonymous
Apr 26, 2020since NG only pushes critical updates via auto that is the best policy
manual updates is NOT recommended
