SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
WrathofKon
May 04, 2020Tutor
So I updated today with no issues to resolve my not seeing connected devices issue. I was seing 8 devices connected before which i knew was too little. Now all devices connected are showing up in the device manager list in the web ui and the app. I did the satellite and then the router. No issues.
- Petiel315May 04, 2020TutorThere is no update to the routers from what I see I have rs40v which need to be rebooted failed
Just a garbage mesh system- WrathofKonMay 04, 2020Tutor
I was using linksys prior to this. This has had better coverage and better speed. And generated few to no complaints from my co-inhabitants. I don't like the app. I didn't like the linksys app either. Using separate apps for parental control is annoying. Asking you to pay subscriptions for this is annoying too.
I found the RBR50 Router upgrade here - https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16For the price I got this system, it has performed adequately for my needs.
- FURRYe38May 04, 2020Guru - Experienced User
Please post about your model orbi in the correct and more appropriate Orbi with Voice forum:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
If you don't like what you have you have the option to return your product or sell it and find something else. Most users enjoy there Orbi systems. Not all Orbi systems are "garbage".
Good Luck.
Thanks for letting us know. Glad all is working well now. Be sure to save off a new backup configuration to file. Saves time if a reset is needed.
Enjoy.
WrathofKon wrote:So I updated today with no issues to resolve my not seeing connected devices issue. I was seing 8 devices connected before which i knew was too little. Now all devices connected are showing up in the device manager list in the web ui and the app. I did the satellite and then the router. No issues.
