SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Petiel315
May 04, 2020Tutor
There is no update to the routers from what I see I have rs40v which need to be rebooted failed
Just a garbage mesh system
WrathofKon
May 04, 2020Tutor
I was using linksys prior to this. This has had better coverage and better speed. And generated few to no complaints from my co-inhabitants. I don't like the app. I didn't like the linksys app either. Using separate apps for parental control is annoying. Asking you to pay subscriptions for this is annoying too.
I found the RBR50 Router upgrade here - https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
For the price I got this system, it has performed adequately for my needs.
