SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Jul 22, 2020Guru - Experienced User
You try a factory reset on the RBR and RBS after the update?
yabanjin
Jul 22, 2020Aspirant
No, I didn't, never had to do that before. Don't want to have to re-enter all the settings as it should be seamless. Other updates were.....
- FURRYe38Jul 22, 2020Guru - Experienced User
I see the same on my RBS50 thats wired too.
Lets see if NG support can pass this on to engineering.
- yabanjinJul 27, 2020Aspirant
Also, why can't we change the list order of connected devices so they show by IP address, or MAC address or, alphabetically, connection type....etc, ?
Seems like a very simple thing to do...
- FURRYe38Jul 27, 2020Guru - Experienced User
Something NG hasn't implemented. Others have asked about this.
You can try this:
https://community.netgear.com/t5/Orbi/Attached-Devices-Sorted-by-IP-Number/m-p/1941711#M97170
yabanjin wrote:Also, why can't we change the list order of connected devices so they show by IP address, or MAC address or, alphabetically, connection type....etc, ?
