SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
Petiel315
Sep 19, 2020Tutor
Sir
I have the same issues
support will not help you
management will not help you
i have filed in my local county court a lawsuit against netgear for the amount of money I have paid for this Orbi garbage
it is absolute trash
tomschmidt
Sep 20, 2020Virtuoso
You are not alone. The Orbi firmware is extremely unstable. I returned mine due to it not meeting advertises specifications. I replaced it with an Asus ZenWiFi AIMesh system and it works so much better, The only issue it has is that any guest networks only broadcast from the base router, they are not replicated on the satellites. Supposedly a firmware fix for this issue will be released soon.
- WrathofKonSep 20, 2020TutorSo since I have upgraded I have had no issues.
You could also look at alternative firmware. There are options out there that people really like. I might consider it in the future.
