SW_
Apr 20, 2020Prodigy
RBR50/RBS50 Firmware 2.5.1.16 Update
Latest firmware v2.5.1.16 on RBK53 in AP mode. No new surprises yet. Everything seems to be in order and working. If you took the plunge, please share your experiences.
jeff022889
Sep 19, 2020Aspirant
Ever since the Firmware 2.5.1.16 Update my WIFI is cutting off every 5 minutes. The outage last only 10-15 seconds which is long enought to destroy connectivity to my many IoT devices. Can someone please give me a work around or solution?
I am considering throwing my $600 Netgear WIFI in the trash and starting over. I work from home and can not tolerate this level of service.
Retired_Member
Sep 21, 2020Why not revert back to the old firmware?
- FURRYe38Sep 21, 2020Guru - Experienced User
Orbi is working for me.
Others as well:
- yabanjinSep 21, 2020Aspirant
Update working for me. Strange issue is the Satellites no longer can determine the attached devices names. They only show IP and MAC addresses of attached devices, yet the router knows and displays them. The satellites displayed the device names before the update.
Still annoying that attached devices can be sorted when being displayed. Seems a simple programming task to be able to sort the list...
Something to contact NG support about and let them know. Seems like they keep fixing this, then it break again after another update or two.
I wonder if v4 or v70 have fix the device naming issue yet.
yabanjin wrote:Update working for me. Strange issue is the Satellites no longer can determine the attached devices names. They only show IP and MAC addresses of attached devices, yet the router knows and displays them. The satellites displayed the device names before the update.
