pankajsingh
Mar 11, 2022Aspirant
RBR50/RBS50 Moving from one router to another
I already have an existing RBR50 (call it MASTER) and RBS50 (call it SATELLITE-1). I needed to have another satellite RBS50 to my network. I purchased another RBS50 (call it eBaySatellite) and it als...
- Mar 11, 2022
If you hardwire into it, can you run it through the sync process?
Mar 11, 2022Guru - Experienced User
What firmware is on the master 1 router?
What firmware is on the satellite you're trying to sync?
They need to be on the same version.
